Motec C127 unable to flash
Hi Everyone,
I have one Motec C127 that has been unable to flash. We've tried two different harnesses (both work with other Motecs), 2 different computers, 2 different ethernet adapters and also manually tried setting the IP per the help instructions
The Motec does not show up when you look for devices,
would someone have been had some similar issue? or would someone could have any recommendation that I could try?
Thank you!
Thank you!
