Setting up a sensor via CAN
Thu Jul 28, 2022 4:03 am
by caleb
Hello, I am trying to hook up a Syvecs 50 hz GPS Module to a C185. I believe that I have it wired correctly, as I have a ground and power from the sensor going to an external 12 V powersource. I then have the two CAN wires from the sensor in pins 73 and 74 (CAN 1 Low and CAN 1 High). I am lost on how to set up the communication between the sensor and the C185. Can anyone help me with this?
Re: Setting up a sensor via CAN
Thu Jul 28, 2022 5:15 am
by David Ferguson
Do you have documentation on what messages the Syvecs transmits? Use that to create a CAN template.
Looks like the details are in the installation manual:
http://www.syvecs.com/downloads/Syvecs_ ... Module.pdfHopefully you connected the 1MB CAN interface from the GPS module, and you added a 100-120 ohm terminating resistor.
Sat Jul 30, 2022 4:42 am
by caleb
I connected the 1 MB CAN interface, but am confused on where to add the terminating resistor. Where do I add this at? Do I attach it between one of the wires between the sensor and the back of the c185?
Sat Jul 30, 2022 7:41 am
by stevieturbo
caleb wrote:I connected the 1 MB CAN interface, but am confused on where to add the terminating resistor. Where do I add this at? Do I attach it between one of the wires between the sensor and the back of the c185?
If it is needed you add it at the end of the bus across the two CAN wires.
Tue Aug 02, 2022 2:30 am
by caleb
Gotcha. I now see that in this diagram in the manual screenshot attached. I guess I am just confused on how the can bus is connected to the c185 then. If I wrap two wires around each other, add terminating resistors at the end, and wire sensors up to these two wires, how does it all come back to the motec c185? What am I missing/do not understand? I appreciate the help and patience.
Tue Aug 02, 2022 3:21 am
by David Ferguson
The little box marked "CAN Device" is the C185, GPS Module, LTC, M1 ECU or any other CAN device.
Tue Aug 02, 2022 5:00 am
by caleb
Okay, that makes sense thank you for the help! Do you have any tips on how to create a CAN template? I understand that I will have to use the Syvecs manual pages that talk about Bytes but am unsure on how to use them exactly within the Motec Dash Manager. I really appreciate the help
Tue Aug 02, 2022 5:15 am
by David Ferguson
This is a big topic, probably best handled by paying someone to create the template for you.
But if you want to learn on your own, start with the MoTeC webinars related to CAN found here:
https://www.motec.com.au/webinars-view/ ... chive/#CANI think this one (What is CAN) might have what you need:
https://www.youtube.com/watch?v=SowbD_09b48 You can skip some of the hundred series ECU stuff, but there is useful dash manager info starting aroung 27:34 or so.
Here is one CAN related tech note:
https://www.motec.com.au/filedownload.p ... docid=5341
Tue Aug 02, 2022 5:24 am
by caleb
Thank you so much! I will watch these and try to learn it.
Fri Sep 23, 2022 12:12 pm
by Ryan
Caleb did you have any luck setting up your gps module? I just purchased 100hz model and am in the process of trying to get it to communicate with a c127. Cheers
