Canbus Transmit Error
Postby jward1000 on Tue Mar 28, 2017 1:52 am
I have a 06 ninja zx14, I purchased a m130 drag race pacakage with plug and play harness. I'm having trouble with canbus transmit error. it cant see the LTC for lamda and my dash board does not work. from the pinout the wiring looks correct is there something I can try to troubleshoot this. maybe a bad LTC?
jward1000
Re: Canbus Transmit Error
Postby Stephen Dean on Tue Mar 28, 2017 7:58 am
The usual causes of this error are;
- Error in the CAN Bus wiring, with the Hi and Lo swapped somewhere.
- One of the devices on the Bus has the wrong speed set
- No terminating resistors, I have found that if there is an issue with the CAN Bus terminations, that the LTC's are the devices that tend to show issues from this first.
Can you check these areas and see if the issue is still there.
Return to MoTeC PC Comms
