CANbus wiring schematic questions
Hi there,
I am looking for some guidance on physical wiring of a canbus for a race car.
The motec documents are a little unclear. I used M800 and PDM15 manuals to reference the CANBUS schematics
The physical nodes are C125, PDM15, Motec UTC adaptor (#61059), Vipec ECU
The Vipec ECU has a internal terminating resistor between can-hi and can-lo and the vipec manual says it must be a terminal node on the CANbus.
A few questions:
1. Both PDM15 and Motec M800 schematics show terminating 100 ohm resistors on both ends of canbus along with a UTC connector as a node. However the manuals also mention that the motec UTC adaptor 61059 has an internal terminating resistor (measured by me as 100 Ohms between can-hi and can-lo). If I wired as per the schematics this would mean there are THREE resistors (two at each end of the bus and one internally at the UTC adaptor). Would this be correct?
2. Does the UTC connector need a terminal node on the canbus or can I have an anywhere along the bus as long as it is within 500 mm of the end?
3. Both PDM15 and Motec M800 schematics show UTC connector wired to CAN-HI and CAN-LO and 0V. However only the M800 schematic shows UTC connector wired to 8V. Does the UTC connector/adaptor require 8V to function? If so, I do not have a Motec ECU - can I wire this to the Vipec 8V out?
Thanks for your time
A few questions:
