Intermittent Operation- UTC
I have a M400 with a UTC and have had occasional problems not being able to communicate with the PC. Usually after a couple of tries it works. I'm currently running Windows 7, 32 bit, but have had the same problem running Windows Vista and Windows XP.
This past weekend at a race it connected fine once, but the next time I tried it would not connect. The engine was really rich at some RPMs and I was trying to make adjustments to the ECU file. I spent probably 15 hours this weekend trying to make it communicate with no luck.
I tried changing the USB cable, changing USB ports on the computer, replacing the pins on the CAN wiring harness at the ECU, running wires directly from the UTC pins to the ECU pins, removing and resoldering the wires on the round CAN connector, removing the cover from the UTC and checking the internal 3 wire connector, reloading the software, and finally changing computers.
I tired connecting and disconnecting at least 200 times over the course of 3 days. Each time I returned from a qualifying run I would try again and again and again and again.
After the last elimination run (I lost) I tried connecting and it worked flawlessly. I was able to download the stored data and upload a revised file to the ECU.
Has anyone experienced this type of intermittent operation? I sent my ECU to Motec (USA) a month or so ago and had them check it out. They did not find any problems.
The only thing left is the UTC ??????
Can I connect using the RS232 wires and not use the CAN/UTC or should I purchase a new UTC and pray that it works?
