Windows 10 Ethernet Issues
Postby Salasko Racing on Sun Jan 27, 2019 2:56 pm
I've recently upgraded my computer and a customers to windows 10. My computer works mostly fine. His will no longer connect to any Ethernet device. I've attached a screenshot of Device Discovery in case it helps. It does not matter whether I use my WiFi device with all his hardware connected or individually connect via a cable, the result is the same.
I have a few random bugs on mine as well, for example if I connect to his C127, then his C125 steering wheel with a physical cable I have to restart my computer in between. If I use my WiFi device I do not have to restart and can switch between the two no problem. I have the same problem between 3 LMP3 cars I support. I have to restart in between connecting to each one.
Any ideas? Anyone ran into the same?
Connection Issues.jpg (601.88 KiB) Viewed 11795 times
Salasko Racing
Re: Windows 10 Ethernet Issues
Postby Salasko Racing on Mon Jan 28, 2019 3:51 am
This was solved by reinstalling MoTeC Utilities. Something must have gone wrong with the initial install.
Salasko Racing
Return to MoTeC PC Comms
