this is my first post to this forum. I'm not really sure if this is correct category, so I will post it here and would kindly ask the moderator to move this message in appropriate category if this one is not ok.
I have a custom made ECU that reads the data from MoTeC M800 via CAN BUS. Everything works ok, until I connect the laptop to the M800. Then, suddenly, CAN "freezes" and can no longer read the channels. As soon as disconnect the cable, everything works as it should. PC to M800 connection works ok.
Is there any way around this? Hopefully there's some setting available in the M800 that I can check ..
Thank you,
Marko
