M150 GPR Rotary Package
Postby Merlin on Wed Jul 16, 2025 2:23 pm
Hi all
Ideas Please
I updated from M130 to M150 to remove the E888 from the car
I have 2 Brake Temp inputs I need to Assign to the AV inputs they are wired to
But the firmware has no allowance for Brake Temp ..
Ideally I would like to log them into Ecu and C127 but if i can only get them to C127 via CAN i would live with that
Any thoughts other than a request to MoTeC to add Brake temps to Firmware
JP
Merlin
Re: M150 GPR Rotary Package
Postby Stephen Dean on Wed Jul 16, 2025 3:21 pm
Brake temps are not in the current GP Packages as they are not a required piece of data for running an engine and associated systems. We have Brake pressures as these are used for functionality like Anti-Lag, Over Run, Cruise Control and Gear shifting.
You can use the Turbo Temp inlet and Outlet for this, as these channels are not used for any control strategies.
Postby Merlin on Wed Jul 16, 2025 3:59 pm
Hi Stephen
Thanks for the Reply
I have GPR package
Can they be added in a future update Pls even if the have no linked functionality other than being transmitted on CAN and logged ?
JP
Merlin
Postby Stephen Dean on Wed Jul 16, 2025 6:17 pm
I'll add it to the list of requests.
Postby Merlin on Mon Jul 21, 2025 9:45 am
Hi Stephen
I used the turbo temps as you suggested
In my C127, As those channels were not in CAN templates 640 or 650 I added 6A0 that had Turbo Bank1 inlet temp and Turbo bank 1 outlet temp
Issue now is I get 0 as value in the C127 in Monitor Channels ...seems to be no data ?
John P
Merlin
Postby Stephen Dean on Mon Jul 21, 2025 12:47 pm
Hi John,
To get it into the C127, you could configure a custom CAN Transmit along the line shown below.
Custom ECU Transmit.png (29.75 KiB) Viewed 3700 times
Postby Merlin on Mon Jul 21, 2025 4:26 pm
Thanks Stephen
I will update the CAN setup
Merlin
