New to MoTeC M150 set up help
Postby Oatesy on Thu Jun 26, 2025 10:38 pm
Hi Guys,
I'm completely new the Motec world, I'm installing an M150, PDM30 and C125 with Single LTC. Have it all wired in and now going through the set up, have most of the inital set up done in M1 Tune with a GPR Package. However I have a CAN BUS issue. The ECU Receive is giving a CAN Timeout Diag error. I'm new to CAN BUS protocol and assume is an address issue.
Appreciate any help on the initial set up and how to configure the CAN BUS addresses. I'm only using CAN BUS 1
Oatesy
Re: New to MoTeC M150 set up help
Postby Stephen Dean on Mon Jun 30, 2025 11:17 am
Do you have anything setup to transmit data into the M1 using the ECU Receive address? If this isn't needed or used, disable the ECU Receive function to clear the warning. The PDM receive data is separate to this.
Users browsing this forum: Bing [Bot] and 5 guests
