M150 PWM Output Current
Hi all, im going to be running an M150 in my new car build and im just working out inputs and outputs to build up my wiring loom.
I will be running a Bosch Pad 12v (0 392 023 004) electric water pump which i believe draws less than 2 amps which id like to pwm control from the M150. Is the M150 capable of running a 2Amp pwm output, or will i have to run it through a solid state relay as with the cooling fan?
Mike
Mike
