Disable injectors- a safe short-term security option?
Sat Dec 21, 2024 10:44 pm
by CraigComet
M150 - sorry for the basic question, but where do you disable the ignition? (Which screen is this found, and is it as simple as toggling something from enable to disable?)
I'm having the car towed to a trim shop and don't want the engine to be able to fire up while it's there.
Thank you!
Re: Disable injectors- a safe short-term security option?
Sun Dec 22, 2024 8:57 am
by David Ferguson
The Engine Run Switch will disable the ignition. Consider changing the mapping of the switch to always off regardless of position.
Tue Dec 24, 2024 11:00 pm
by CraigComet
Thank you David, that's exactly what I was looking for.
Thu Dec 26, 2024 9:12 pm
by stevieturbo
Often better to disable the fuel side of things. That way should anyone crank the engine over, it isn't dumping fuel in.
Fri Dec 27, 2024 4:22 am
by David Ferguson
THe Engine Run Switch stops both fuel and ignition.
