GPRP Shifting Setup
Hello, we are trying to setup shifting in our Motec M150 using the GPRP package.
We are using a relay to activate our electric actuator in order to change gear. In order to activate this relay: one of the two wires is connected to a 12v from battery and the other is connected to a low side ignition pin on Gear-> shift -> actuator -> down. When we turn on the test option, it does not activate the relay.
This setup is very similar to how we activate our coolant fan. In M1 tune, we set the shifting relay to the fan output and tried the test, and it immediately activated the relay. Yet it doesn't work when set up as a Gear Shift Actuator.
I was hoping if you could help us figure how to activate this relay for our actuator. Does the test feature not work as we are expecting?
