Cooling fan wont start. newbie alert!
Postby justineurope on Sun Sep 29, 2024 10:14 pm
So got the car running, discovered faulty head gasket, rebuilt head and its running again. now It runs for longer it gets up to temperature but the fan is not kicking in as programmed when the water temp reaches 92 degrees. The fan works when the test is run. I'm assuming somewhere in the programming a condition is not being met but for the life of me I cannot find it.
motec coolant fan.jpg (114.17 KiB) Viewed 6217 times
any thoughts I can try.
justineurope
Re: Cooling fan wont start. newbie alert!
Postby greenamex2 on Mon Sep 30, 2024 1:19 am
Got any relevant data logged?
greenamex2
Postby justineurope on Mon Sep 30, 2024 4:31 pm
greenamex2 wrote:Got any relevant data logged?
What data would be helpful in logging?
Cheers JP
justineurope
Postby David Ferguson on Tue Oct 01, 2024 4:13 am
What does the table Coolant Fan 1 Duty Cycle Coolant Temperature look like? You could have a single value (no axis enabled) with a value of 100. (or any non-zero value since this is a switched output).
Postby Stephen Dean on Tue Oct 01, 2024 12:24 pm
As David said, The Duty Cycle needs to be set to 100% with a switched output.
Postby justineurope on Sun Oct 13, 2024 12:50 pm
Hi Guys, thanks for the help, I have reset it to 100% to no avail.
any other thoughts
cheers
JP
justineurope
Postby David Ferguson on Sun Oct 13, 2024 1:01 pm
Can't tell, is the engine running when you took that screen shot?
Postby justineurope on Sun Oct 13, 2024 1:04 pm
yes it was running.
justineurope
Postby Stephen Dean on Mon Oct 14, 2024 9:16 am
Can you post your configuration thanks.
Postby justineurope on Mon Oct 14, 2024 8:35 pm
Here it is. Pretty sure its the same as the one you sent me a while ago. I don't think i've messed with it other then trying to get fan to work. Just a reminder. using the test function the fan runs. I may have set the trigger temperature low to test rather then at near boiling.
Thanks in advance
justineurope
Users browsing this forum: Baidu [Spider] and 20 guests
