Fuel Pump Control
Fuel Pump Control
Postby ChitoFK8 on Sat Aug 24, 2024 7:47 am
New to motec, recently got motec on my 2019 Civic Type R. I been having issues with the Fuel Pump not powering. This issue is intermittent, at time about 2 weeks apart. I changed the fuel relay and checked all of the fuses were good.
I installed the OEM ECU to run the OBD2 Scanner, scanned PGM-FI, no codes, commanded the fuel pump to prime.
Is there a way to command the fuel pump in motec?
ChitoFK8
Re: Fuel Pump Control
Postby greenamex2 on Tue Aug 27, 2024 5:55 pm
Which Motec ECU?
Which M1 package?
How is the fuel pump connected?
greenamex2
Postby ChitoFK8 on Sun Sep 01, 2024 7:11 am
I have M142, the fuel pump is connected OEM. I lose power to the fuel pump about every 2 weeks. It doesn't prime or nothing.
Connecting the OEM ECU and commanding the fuel pump was pure luck last time. It happened again today 31 Aug. No power to the fuel pump. I got a code P0560 when hooked up the OEM ECU.
Not sure if its just coincedence but it happens about every 2 weeks I lose power to the fuel pump and it randomly starts working again. I've put a new fuel pump in, change the fuel pump relay and battery is good.
ChitoFK8
