i need help with matching file of m130 & m150 with mitsubishi evo8 ecu 4 pin socket
i need to build adapter between evo8 4 pin socket to m130 ecu
David Ferguson wrote:Do you have documentation on your wiring? My preferred method is to create the M1 config package, then wire the engine to match the config. If while wiring I find something that needs to be moved, I change it in the M1 package at the same time.
Usually a factory workshop manual with wiring diagrams is needed to understand what the pins connect to and how they function.
