M150 with water/methanol
Hello, I am a new member in this forum. My name is Asier.
We have been developing a project for some time. It is a single seater with a 1000cc BMW S1000RR motorcycle engine and we have installed a Garrett G25-550 turbo among many other things. The electronic system is complemented by a Motec M150, PDM15 and an E888 module.
The engine, like all modern motorcycle engines, has 8 injectors. 4 in the primary ramp and another 4 in the secondary ramp.
Now we want to implement a four-port water/methanol system. 1 nozzle for each cylinder. The thing is that we want to go a little further and we want this water/methanol spraying to be sequential as if it were a fuel injection. I want the spraying to occur in the intake cycle when the valve is open and not a continuous spraying like conventional systems. I want to avoid water build-up in the intake manifold while the valve is closed.
The problem is how to achieve that.
Has any of you tried this before or have any ideas? Do you think it can be done through the motec?
