Subaru BRZ
Tue May 07, 2024 2:57 am
by mdn-t
Hello. Which ECU from M1 is more suitable for installing on a Subaru BRZ? The goal is to control the di injectors directly via the native injector driver. The dashboard, the keypad, the pdm will be a motek. Which packages should I use for this?
Re: Subaru BRZ
Tue May 07, 2024 9:04 am
by SOReilly
We offer a targeted solution for the Subaru BRZ/Toyota 86 which uses an M150.
An adapter loom allows the M150 to replace the standard ECU.
You can read about it on the product page at the link below:
https://www.motec.com.au/products/engin ... 12%20FA20D
Re: Subaru BRZ
Mon May 13, 2024 1:53 am
by mdn-t
SOReilly wrote:Hello,
Hello. I saw that. I don't have any drain wiring. I am interested in which ECU and package to use for a custom project? Without using the standard direct nozzle control driver .
Re: Subaru BRZ
Mon May 13, 2024 10:11 am
Which engine do you have? The FA20D or the FA24D? We have a M142 Firmware for the GR86 (current model) that directly controls the DI system using the DI drivers in the M142. The previous generation T86/BRZ used the M150 and the OEM driver box to control the DI.
Re: Subaru BRZ
Mon May 13, 2024 4:18 pm
by SOReilly
If you do not need any vehicle integration e.g ABS, air conditioning, then you would use an M142 w/ GPR-DI.
mdn-t wrote:SOReilly wrote:Hello,
