Huracan Dyno Mode
Huracan Dyno Mode
Postby TurboTim on Fri Mar 29, 2024 10:16 am
Does anyone know how to get a Performante into Dyno Mode?
TurboTim
Re: Huracan Dyno Mode
Postby NathanB on Sun Mar 31, 2024 2:25 pm
In which sense are you wanting to put the car in dyno mode?
If you are attempting to dyno the car on a 2wd dyno, the only safe method of dynoing these cars is with the prop shaft disconnected.
Outside of that there is the roller bench test mode in the ABS system via VCDS.
If trying to set any module states with VCDS or similar, ensure you have OBD mode set to 'not in use' (this will require a power cycle after changing a setting)
You also have the Huracan VDC torque gain you can manipulate to lock these systems out from setting torque limits on the dyno.
Postby TurboTim on Sun Mar 31, 2024 11:09 pm
I have the driveshaft out and will check the settings you mentioned
TurboTim
