Quick way to convert from E85 to 98RON (efficiency table?)
Hi
I'm wondering if it is possible to change an E85 tune so that it can get me home on 98RON in an emergency? This is on a supercharged 2017 Mustang with a M150 (plug and play GPR to suit the Mustang).
For example, if the engine is running perfectly on the E85 tune and I absolutely needed to run a couple of tanks of 98RON petrol, could I jump into the Efficiency Table and adjust fuel type/fuel density, molar mass, stoich ratio. Save those changes and will the system then hit the new lambda targets for petrol without further changes?
Why am I asking such a question?
I am buying a car this week. The seller had the Motec installed and has only ever run the car on E85. He doesn't believe that it has a flex fuel sensor, or that it has been tuned for 98RON, although I won't know until I connect a laptop and have a look. I will be flying 900km to the car and driving it home. There SHOULD be service stations selling E85 along the way, but if two particular service stations have any supply issues, I will be about two tanks of fuel short to get home. I'd prefer not to carry a spare 120 litres of E85 in the car with me, so was hoping that at a pinch, I could make the changes to the fuel type / settings so that I could run 98 octane petrol. I will just be cruising at light load, not getting into any boost at all, so I don't have any concerns that the ignition table will be too aggressive for the 98 fuel as I'm cruising down the road.
Thanks for any guidance.
I will definitely be setting up a flex sensor as a priority and I have a feeling that there will be countless features of this M150 GPR install that the seller didn't know about, or forgot. I can't wait to connect a laptop and find out all about it. First step is to make it home.
Thank you
Thank you
