DBW throttle pedal over CAN?
Postby greenamex2 on Tue Mar 12, 2024 3:08 am
Hi all
I think I already know the answer but is it OK to transmit throttle pedal position over CAN and what would be the minimum acceptable transmission rate?
The reason I am asking is I am not totally happy with my current method (a "frequency" based sensor), I have run out of AV inputs and am considering adding a normal analogue sensor to either a dash, E888 or similar and then sending over CAN.
greenamex2
Re: DBW throttle pedal over CAN?
Postby NathanB on Tue Mar 12, 2024 8:07 am
It is obviously not ideal for a safety related item to be on CAN where possible. Can two of the other AV's for something else be moved over to the E888 instead? For instance oil or fuel pressure?
Outside of that, you will need the pedal position to be updated at 200hz to minimise any abnormal behaviour.
Postby greenamex2 on Tue Mar 12, 2024 8:33 am
Thanks NathanB
Good idea on moving less critical sensors on to CAN. This would mean the throttle pedal sensor would be on the end of a 2.5 metre run of wire. Does that sound OK? I guess as any voltage loss would be constant, EMI aside, it would probably be OK.
greenamex2
Postby Stephen Dean on Tue Mar 12, 2024 10:07 am
A lot of cars have a longer run than that and work without issues.
Postby greenamex2 on Tue Mar 12, 2024 6:44 pm
Thanks all, I'll keep an eye on my current setup and see if I get weird changes again.
greenamex2
Users browsing this forum: No registered users and 147 guests
