by Stephen Dean on Mon Feb 19, 2024 11:20 am
If I recall correctly, the Non VVT equipped 2JZ engines used a 12 tooth crank trigger with a single sync tooth on the Cam, so this will use the Multi Tooth Four Stroke Reference Mode with 12 set for the Engine Speed Reference Tooth Count. You will need to do an Input Capture to set the Sensor type and Edges in use.
As for the remained of the setup, all of the 2JZ Packages that I have seen use different sensors, coils and injectors from the OEM, so there is not a base Package that can easily be used to start with
