Injector location setup in blower engine
Postby Mievaan on Mon Feb 12, 2024 12:06 am
I am building screw charged engine with 8*primary and 8*secondary injectors, M150.
What is correct injector location setup when primary injectors are in intake manifold and sees vacuum/boost, and secondary injectors are between throttle and screw, and sees vacuum only.
Mievaan
Re: Injector location setup in blower engine
Postby Stephen Dean on Mon Feb 12, 2024 9:12 am
I would have them both set to After Throttle, making sure that the Fuel Pressure Regulator Type is correctly set.
