How to assign the same resource to multiple functions
This may be a stupid question but is there any way to use the same resource twice? Meaning I would love to assign an output for use with multiple functions but once it's been assigned to one it's no longer available to select in the dropdown menus.
For example I'm using INJ_LS6 for a solenoid and it's currently assigned to a function, but I want to setup another custom aux table that can also trigger INJ_LS6. Now I figure I could also use another resource output and just wire it up to the same solenoid but there has to be some way to just select the same resource like I can do in other ECUs, unless it's just not possible here?
Just trying to avoid using another output if it's something I can do in the software as I'm running out of those...
