Engine stop from tune?
PostPosted: Thu Sep 28, 2023 4:11 am
by greenamex2
Hi all
Is there a keyboard shortcut or similar in Tune to stop an engine? Looked and looked and can't find anything.
Thanks in advance
Re: Engine stop from tune?
PostPosted: Thu Sep 28, 2023 10:07 am
There is not a dedicated engine stop function in Tune, this could lead to the accidental shut down of an engine if the wrong key combination was pressed. You can reset the M1 by changing a red flagged parameter and doing a save, other wise you can change the Engine Run switch state to turn off the injectors.
My preference is that you have an Engine Run switch wired into the M1 so that you can shutdown the engine using this.
