Inlet Camshaft Bank 1 Position Diagnostic
Postby dochka on Wed Sep 20, 2023 7:42 am
After Flashing the JRR Firmware into the M130 ECU installed in a Mitsubishi Evo 7 with a Adaptor Loom, I've got this warning...
What is the cause and how to fix it ?
Attached some pics
Thanks for your input
Kam
zouz missing.png (148.21 KiB) Viewed 8867 times
z cycle.png (162.9 KiB) Viewed 8867 times
dochka
Re: Inlet Camshaft Bank 1 Position Diagnostic
Postby David Ferguson on Wed Sep 20, 2023 10:54 am
That is indicating there is no signal from the Inlet Camshaft Bank 1 Position sensor. You might check that's it's plugged in, inspect the wiring. If that doesn't find anything, then review the configuration and determine what resource is configured for that sensor, check that it you have continuity from that pin on the ECU all the way to the sensor.
It's possible you could have a configuration issue -- say that sensor is really a hall-effect sensor, and yet it's not configured with a pullup control turned on, or the threshold isn't above zero or something similar.
You will likely find all of these on the worksheet "Initial Setup 2->Cam Control Inlet".
Did this only start happening after you updated the JRR firmware, or is this the first time you've gotten the engine running on this firmware?
Postby Stephen Dean on Wed Sep 20, 2023 11:11 am
It's a wiring issue, the M1 is not receiving a signal on the allocated Universal Digital input.
Postby Kam on Thu Sep 21, 2023 10:25 am
David Ferguson wrote:That is indicating there is no signal from the Inlet Camshaft Bank 1 Position sensor. You might check that's it's plugged in, inspect the wiring. If that doesn't find anything, then review the configuration and determine what resource is configured for that sensor, check that it you have continuity from that pin on the ECU all the way to the sensor.
It only started happening after the firmware update
Kam
Postby Kam on Thu Sep 21, 2023 10:27 am
Stephen Dean wrote:It's a wiring issue, the M1 is not receiving a signal on the allocated Universal Digital input.
The engine is a 4G63 from a Mitsubishi Evo 8, with no variable valve timing..
How does it "Cycle Lock" if it doesn't receive the Camshaft Signal ?
Kam
Kam
Postby Stephen Dean on Thu Sep 21, 2023 11:11 am
Does it have the Sync sensor wired in and configured? The 4G63 engines have a separate sync sensor to the inlet cam position sensor.
Postby David Ferguson on Thu Sep 21, 2023 11:14 am
If you don't have VVT, you could just de-configure that resource (change the position resource to "Not in Use") to eliminate the diagnostic error.
Postby Kam on Thu Sep 21, 2023 11:17 am
David Ferguson wrote:If you don't have VVT, you could just de-configure that resource (change the position resource to "Not in Use") to eliminate the diagnostic error.
Yep, thanks
I did that :)
Kam
Postby Kam on Thu Sep 21, 2023 11:19 am
Stephen Dean wrote:Does it have the Sync sensor wired in and configured? The 4G63 engines have a separate sync sensor to the inlet cam position sensor.
Yes,
I also read the sync sensor voltages in the MoTeC M1 software and think they're right
Kam
