Difference between SEN_0V_A1 and SEN_0V_B1
Hi All,
I'm getting to grips on the wiring of the M142 for a diesel project.
Looking at the wiring doc from the PDF it has;
A33 SEN_0V_B1 Sensor 0V B
A34 SEN_0V_A1 Sensor 0V A
B26 SEN_5V0_A Sensor 5.0V A
C02 SEN_5V0_A Sensor 5.0V A
C09 SEN_5V0_B Sensor 5.0V B
D15 SEN_0V_A Sensor 0V A
D16 SEN_0V_B Sensor 0V B
D03 AT1 Analogue Temperature Input 1 1k Pull up to SEN_5V_A
(not all pins listed for brevity)
Given the A,B,C context. I'm assuming it's an 'A', 'B' and 'C' circuit where all the A's connect, all the B's connect etc.
In the case of D03 the circuit is part of 'A' so an analog temperature input (using 3 pin sensor) would make use of:
C02 SEN_5V0_A Sensor 5.0V A -> This is the 5V
D15 SEN_0V_A Sensor 0V A -> This is the low/gnd
D03 AT1 Analogue Temperature Input 1 -> This is the signal line.
Have I got this right?
Thanks for any help.
Mathew
Mathew
