M130 GPA Duratec 36-1 Crank Only
Postby Monaser on Mon May 15, 2023 11:06 pm
Hi
what are the possibilities for motec to run this mode 36-1 crank sensor only, as i was trying before with linkecu but with the ecu limitation to that trigger mode i couldn't run it, so can i do this with motec with choosing multi tooth with missing and batch fire? or i need to fit a cam senosr to get the Ford Duratec mode work it out for me?
Monaser
Re: M130 GPA Duratec 36-1 Crank Only
Postby NathanB on Tue May 16, 2023 2:12 pm
With a 36-1 crank only, you would use 'Crankshaft One Missing Two Stroke' mode.
This will require you to run batch fire and wasted spark. You would also need to set the number of cylinders to half the actual number present, and often the engine displacement needs to be halved to get all the engine loads etc calculated correctly.
The Duratec and Mazda L3 reference modes require very specific camshaft trigger patterns, which match various VVT variants of the engine.
If you were to add a single tooth for a cam sensor, you would switch to 'Crankshaft On Missing Four Stroke' for sequential operation.
Postby Monaser on Tue May 16, 2023 7:19 pm
Hi Nathan
thanx for the reply, this engine is AUD style cosworth and comes only with crank trigger in, i got it fired up with 4 stroke one missing but faced a lot of noise there and ref errors, i will try your settings here and see where it will put us.
Thanks for the help
Monaser
Postby Monaser on Wed May 17, 2023 5:51 pm
tried the setup u gave me with no luck
so i fitted a cam sensor with one tooth and did a scope and was good, still when i try to crank it it keeps giving me missing error at the sync log.
attached the package for the reference
GPA (M130) [01.11.0099, July 2019] AD Cossie Exige , Duratec Exige V3.m1pkg-archive
(2.03 MiB) Downloaded 680 times
Monaser
