15 Button Keypad wake up on M141
Postby Tasboost on Mon May 15, 2023 10:25 pm
Hoping someone might be able to assist me with getting a Motec 15 button keypad to wake up on my M141.
I have Driver keypad enabled and set to CAN bus 1, CAN ID base set to 0x0506 and Node ID set to 0x0a.
I have setup some toggle switches as a test but I get a communications error…
Could it be that the Motec switch panel is operating at a rate of 1000 and CANBus 1-3 are all set to 500 in my ECU (Motec m141 for Toyota GR Yaris) or do I also need to tell the keypad to wake up?
I also have a C125 dash but would prefer to configure the keypad using the m141 as the gateway.
Appreciate any advice you may have.
Many thanks,
Nick
Tasboost
Re: 15 Button Keypad wake up on M141
Postby SOReilly on Tue May 16, 2023 9:56 am
Hi Nick,
As supplied the keypads are configured for 1Mbps bitrate.
PDM Manager includes a keypad configuration tool which you can use to change the bitrate and IDs of keypads.
To use the configuration tool you will need a MoTeC UTC to communicate with the keypad.
If you require assistance changing the bitrate of your keypad you should contact the MoTeC dealer that supplied your hardware.
SOReilly
