I do have a M130 ECU and an E888 where I would like to use the PWM outputs to control the cams on a Ford Duratec 3.5 TI-VCT engine.
My intension was to use the E888 PWM outputs 1/3/5/7, but I'm not able to control either of the PWM ports 3/4 and 7/8 from the M130.
I've tested all the E888 PWM outputs from the M1 Tune, Engine Systems / Auxiliary Outputs tab, and I was only able to operate PWM port 1/2/5/6. The rest of them did not respond.
I'll appreciate any help to get this sorted. I've attached the setup and diagnostic of the E888 from M1 Tune.
Rolf
