Help with DBW pedal
PostPosted: Mon Mar 27, 2023 12:42 am
by ZT-R
Hello
I have a M150 and have this pedal BDBW-GM06
Lokar
https://www.lokar.com/throt-assemb-pedal-pads.html
All GM Crate Engines, '08-'12 Cadillac CTS/CTSV, and '10-'12 Camaro #10379038, #10367117, #22741799, #22741800, and #92199239
https://www.lokar.com/assets/instructio ... ByWire.pdf
The number on the Sensor is Williams Control 134734
I think this may be a data sheet for it but im not sure. the works on the Apps side but not the other 3 wires. but this is beyond me as well.
https://www.cw-industrial.com/getmedia/ ... t?ext=.pdf
Re: Help with DBW pedal
PostPosted: Mon Mar 27, 2023 8:44 am
That Williams control setup is not acceptable for a DBW pedal as it only has a single sensor output. The Lokar one can be used.
PostPosted: Thu Mar 30, 2023 12:07 am
by ZT-R
Thre lokar one is what I bought (GMO6) and the senor that is on the side of it is the Williams.
PostPosted: Thu Mar 30, 2023 4:15 am
Your Williams Controls data sheet is not for the sensor as programed in the Lokar pedal. I am trying to get you the correct data sheet, but I would think you could go with the info in the Lokar instructions -- that indicates it should work with the MoTeC DBW Pedal setup,as there are two analog voltage outputs.
PostPosted: Thu Mar 30, 2023 5:06 am
I couldn't get a complete data sheet as the outputs are programmed for different customer requirements, but here is the pinout for 134734 that clearly shows two APS outputs.
PostPosted: Mon May 01, 2023 11:01 am
by ZT-R
That got it, thank you sir!
