OE Analogue Temperature Input Sharing
Hi all,
I'm new to the forum and will likely be posting frequently from now on since I'll be buying a second-hand M130 GPRP.
I'm reading as much as possible and finding my way around the software but some questions have been popping up. My past experience in the street car world has been with Fueltech and Megasquirt ECUs. I also work for Core Calibration at Stellantis, so there's a decent background with Bosch, Marelli, and in-house control software.
My question now is on sharing input NTC analog temperature sensors.
The way the vehicle sits, I must still share some essentials to keep the car operating as OE. There is no CAN integration with the M130 so far and no plans in the near future due to other priorities.
Given that:
How can I share an analog temperature sensor in the M130 with the OE wiring spliced together? Is selecting the voltage reference to "Absolute" enough or is there another configuration available to turn off the Pull-up resistor? The reason why I ask this is that the OEM ECU still needs access to that data and is spliced together with the current vehicle wiring. I will be sharing both coolant and intake air temperature sensors.
In the Fueltech software, I could check a box and turn off the pull-up resistor. In the MS3X that required me to de-solder a resistor (not something I quite enjoyed doing)
Regarding their transfer curves. I took data using freezing to slowly boiling water using an RTD as a reference temperature measurement and measured the resistance of the sensor.
In the Megasqurit, we use the voltage divider equation and plug-in resistance to get the software read voltage. Fueltech requires a direct voltage calibration with the sensor hooked straight to it. From what I've seen so far I believe that the Motec will require a direct voltage-to-temperature transfer curve (haven't found data anywhere telling me what is the bias resistor's resistance to doing the math with the data I have).Is this a correct mindset or does anyone have information on the internal Bias resistor?
Thank you for the assistance,
Given that:
