Standard Motec and SkiDoo can together on one bus
I have a plug and play M130 kit on a 2018 SkiDoo 1200. The M130 has the can bus set up to run all the factory dash functions like reverse, hand warmers, air suspension, tach and speedo. I bought a dash that can read the standard Motec data stream or any other stream with the correct CANX file, to supplement the data the stock dash is missing, AKA "all the fun stuff" The problem I'm having is that I believe the standard Motec can stream has been turned off in favor of the custom can stream that's running the stock skidoo stuff in my M130. Can both the custom Skidoo can stream and the standard Motec stream "much more available info than SkiDoo stream" be put on the same can bus since the m130 only has one can bus to work with? Wouldn't even running a Motec dash still need both the SkiDoo and standard Motec cans on the same bus to work even with all the Motec and Skidoo stuff at the same time?
