M1 ECU's
M1 ECU's
Postby GWRMOTORSPORT on Tue Oct 25, 2022 5:29 am
Hi, one for the software writers
just wondered if there was thoughts on adding the 'start mode' setting,
'batch,sequential' to the M130 GP Lite range, or the old 'one tooth per fire'
to all the range. Opens up a small market to use M1 on engines that have a fixed
ref only setup.
Many thanks
Steve
GWR Motorsport
GWRMOTORSPORT
Re: M1 ECU's
Postby NathanB on Tue Oct 25, 2022 8:36 am
Hi Steve,
Version 51 of the firmware already has batch fire mode.
Due to how the workbooks have been put together, it doesn't show up in the ref/sync worksheet, however if you go to all calibrate and type "start mode", you can select sequential or batch fire start modes
Re: M1 ECU's
Postby GWRMOTORSPORT on Tue Oct 25, 2022 9:04 am
Hi Nathan
ah, just found it, brilliant, thanks for the quick reply
Regards
Steve
GWRMOTORSPORT
