CAN BUS timeout
I have a PNP M150 system that I purchased from John Reed for my 2009 CTSV. Everything has been working great until I installed an aftermarket radio in my car. The radio required the use of 2 external interface devices so that I could still use my back up camera, and my steering wheel controls for radio volume. I believe that somehow something in that system used the CAN BUS for communication to the BCM.
Now my problem is ever since then I have a CAN BUS timeout for both Exhaust Lambda Bank 1 & 2 LTC diagnostic. So, I have no 02 readings and I cant continue in the tuning process with the car. Everything else with the car performs as it should, just no 02 readings now.
I reached out to John on friday, and will wait for him to respond...but I decided to go ahead and ask here to see if anyone had any input.
I had the battery disconnected when i did the install, but could the Lambda CAN to Dual adapter have shorted out/went bad?
