Idle fueling is changing constantly.
I'm experiencing an issuue with fueling on idle with closed loop fueling turned off.
If i tune the engine lambda 1,0 at 80 degrees on coolant and say 40 on oiltemp. My engine wan't like 52%.
When the temp rises to 85c and oil temp catches up to like 80c it starts to run leaner, like lambda 1,1x. I need to increse the fueling to 60%.
I have no idea why it does this. I can expect the engine to run with less friction on higher temps but would it really notice this much?
Fuel temp is about 20degrees when first starting and at about 30c when oil is warm.
Is there a compensation for this? I don't notice much on load. It's mostly at idle i see this difference.
Im aware that the closed loop lambda would regulate this im just curious if this is a normal behavior and if it can be corrected.
