Reduce cranktime
Reduce cranktime
Postby Dantla on Fri Sep 09, 2022 7:10 am
currently the engine cranks about 2 seconds until it got at least one full revolution of the sync sensor. During this time the 'Engine Synchronisation Position Diagnostic' is on 'Search' and 'Engine Speed Reference State' on 'Revolution Lock'. According to a reference measurement I did with an oscilloscope, the ignition starts early, but injection not. Is there a setting how it starts the injection faster?
I mean, as soon as the ref position is clear by detecting the gap (I'm using a 60-2 trigger wheel) and the polarity of the sync sensor is known, the position shoul be clear right? The start mode is already in 'Batch Fire'.
And second question: The 'Engine Synchronisation Position Tooth Index' increases up to 127 and then resets. Is there a reason for this range?
Thanks and best regards,
Kilian
Startup tuning M130_range.ld
(2.49 MiB) Downloaded 613 times
Dantla
Re: Reduce cranktime
Postby Dantla on Fri Sep 09, 2022 7:14 am
Here is the osci screenshot:
The engine is an inline 6 cylinder with sequential injection but wasted spark ignition. Sync sensor is low when cylinder 1 is in compression TDC.
Dantla
Postby Stephen Dean on Fri Sep 09, 2022 12:57 pm
Can you do an Input Capture through M1 Tune thanks, and post it here.
Postby Dantla on Fri Sep 09, 2022 6:40 pm
You mean like this, only speed reference and synchronisation?
InputCapture_Cranking1 M130 #3284.m1inc-archive
(142.74 KiB) Downloaded 865 times
Dantla
Postby Stephen Dean on Mon Sep 12, 2022 3:29 pm
I have made some small changes to the setup, can you load and test this thanks.
GPA (M130) [01.11.0041, July 2019] Kilians Jeep , Jeep Wrangler TJ 4,0L with Flex Fuel_Geovane_destruction.m1pkg-archive
(1.96 MiB) Downloaded 749 times
Postby Dantla on Tue Sep 13, 2022 7:26 am
Thanks, I'll check it the end of the week!
Dantla
