Barra Cam reference
PostPosted: Mon Jul 04, 2022 2:43 pm
by slo32
Hi Guys
Can anyone help me with Barra Cam reference values
Have an M130 that was running AU SOHC 4.0 now changed to barra engine
DBW,VCT & cam sensors all wired in
I believe the crank trigger will still be correct both being 36-1
Jason
Re: Barra Cam reference
PostPosted: Mon Jul 04, 2022 3:41 pm
The Ford Duratech Reference Mode should be the correct mode for this engine. if you have an Input Capture, this can be verified.
PostPosted: Mon Jul 04, 2022 5:34 pm
by rntechnologies
Yep, as Stephen mentioned.
Ford Duratec mode, most likely with an offset around 400-420
Crank and Cams are Mag
PostPosted: Tue Jul 05, 2022 11:07 am
by slo32
Thanks guys
