M130 Ignition Coil Calibration Bosch (coil on plug)
Postby jeffkraftwks on Sat Jun 25, 2022 10:08 am
Hello, I am looking for the correct Coil Calibration for Bosch coil 0 986 221 024
The M1 package presently has a preset configuration for "Audi VW 06E 905 115E.1.0 This coil is similar in appearance to the ones installed, and at this point the engine runs with this calibration. However, since it is a different part number I would like to confirm correct settings. I searched the forums and was unable to find an answer.
Thanks for your help,
Jeff
jeffkraftwks
Re: M130 Ignition Coil Calibration Bosch (coil on plug)
Postby rsscotty on Sat Jun 25, 2022 12:15 pm
Dual Bosch 0 986 221 024 coils on one output
Dwell 1.7ms for 10.4A at 14v
Overdwell is 19.2A
Coils are said to fit a Porsche twin plug head perfectly
Pin-out
1 = switched Ignition Power
2 = logic ground
3 = EST signal
4 = Igntion High Curent Ground
8v = 7.0ms
10v = 3.0ms
12v = 2.2ms
14v = 1.7ms
16v = 1.4ms
18v = 1.2ms
I received this information from simon@motec
rsscotty
Postby jeffkraftwks on Sat Jun 25, 2022 11:54 pm
Thanks rsscotty for the helpful info.
Coils are installed on Porsche twin plug air cooled head as you said, fits great.
jeffkraftwks
Postby iivvaann12 on Sun Jun 26, 2022 8:56 pm
I have bosch 0 986 221 023 do you maybe know if they are the same internally? Can I use the same calibration values?
iivvaann12
