M142 GPR-DI Firmware
Fri Jun 10, 2022 9:52 am
by bing
If i use M142 for non-di application, what are the correctly way to setup primary injector to use port injection since there are no selection for Port injectors (ID1050x)
Thanks,
Brian
Re: M142 GPR-DI Firmware
Fri Jun 10, 2022 10:41 am
Hi Brian,
The Primary injector drivers in a DI M1 ECU cannot be used with Port injectors. The DI injector drivers are High Side outputs that are designed to drive the DI Injectors, this means that they are putting out a higher voltage and current than is required to drive a port injector. This output voltage and current will quickly damage the Port injectors.
Fri Jun 10, 2022 12:06 pm
by bing
I understand, i mean if i select output resources Fuel Cylinder x Primary Out using Low Side Injector X and wire as port injection not using direct injection driver. I wonder if this is possible.
And if software setting are possible as well.
Thanks,
Brian
Fri Jun 10, 2022 3:21 pm
by NathanB
The injectors will need to be set as secondaries, and the secondary contribution needs to be set to a single value of 100%
In GPR-DI the primary injector is hard coded with the direct injector diagnostic settings, so you cannot assign a low pressure port injector to the primary injector correctly.
Sat Jun 11, 2022 12:24 pm
by bing
Thanks for the info Nathan.
