m3 e46 coils
m3 e46 coils
Postby Lutek on Tue Apr 12, 2022 2:27 am
Anyone have info about stock m3 e46 coils if they are active or passive and can work with m150?
Thx
Lutek
Re: m3 e46 coils
Postby Stephen Dean on Tue Apr 12, 2022 10:09 am
Do you have a part number for the coils that you are using? Searching for M3 E46 coils comes back with a couple of options but the main one that I have found is the Bosch 0 221 504 464 that we have a calibration for.
These coils require an external igniter (such as the IGN4) as they are a "dumb" coils.
Re: m3 e46 coils
Postby Lutek on Sun May 01, 2022 9:47 pm
Thanks for answer
They were passive.
Just for quick solution I used audi coils.
But I have one more question actually. Do you know if stock DBW motor can be driven without dual half bridge module? as I have wired directly form m1 for now and I was wondering if it will be fine.
Lutek
Re: m3 e46 coils
Postby NathanB on Mon May 02, 2022 9:43 am
A bridge output on the M1 ECU is sufficient to drive a DBW motor. the ECU HB outputs are rated for 9A high side and 12A low side which is more than sufficient to control a DBW motor.
Re: m3 e46 coils
Postby Lutek on Tue May 03, 2022 8:46 am
Yeah I can read technical data. In past this car had ecu master and their dual half bridge because I was told this motor is able to take up to 20 A. it has this rod driven Itb's. emu black is capable of Full bridge up to 7A so I took as granted that M1 will hold it
I was just courious if it won't overheat output
Lutek
Re: m3 e46 coils
Postby Stephen Dean on Tue May 03, 2022 10:15 am
What motor is it that you are using?
Re: m3 e46 coils
Postby Lutek on Wed May 04, 2022 6:04 pm
You can have a look in that video.
https://www.youtube.com/watch?v=az8OJxlf5oA
it is stock e46 m3 system
Lutek
Re: m3 e46 coils
Postby ElectronSpeed on Thu May 05, 2022 7:12 am
The M1 series ECU can easily run that throttle system.
Things to avoid:
excess friction of the steel rod that runs across the top of the aluminum throttle bodies, and
bouncing the throttle of the bore.
Realize that the two throttle sensors are not perfectly linear in relation to each other. Care should be taken when setting them up to minimize errors between the two readings.
Have fun.
ElectronSpeed
Re: m3 e46 coils
Postby Lutek on Thu May 05, 2022 7:22 am
Yeah, using sensor connected to shaft on butterflies was useless and voltage translation was horrible at low throttle opening. Ended up using only sensor on motor which provided reasonable voltage translation just twice I’ve had issue with tracking aim values at idle as m1 output was 80% duty and motor didn’t move at all as it was stuck in that position. I’ve changed some settings to have bigger tracking tolerance and some other setup and didn’t have that issue again
Lutek
