Quick Shift Sensor
Quick Shift Sensor
Postby Ralle#67 on Mon Feb 14, 2022 12:56 am
I am looking for a suitable Quick Shift sensor for my Ducati Panigale with motec M1 GPR package. I have a Dig input, and an AV input for Gear Shift Force. Maybe someone has a tip.
Regards Ralf Fischer
Ralle#67
Re: Quick Shift Sensor
Postby David Ferguson on Mon Feb 14, 2022 4:53 am
How about this one:
https://www.moto46.co.uk/product/strain ... -panigale/
if that's not right, then I've successfully used this strain gauge with many MoTeC ECUs:
https://www.kasensors.com/en/products/gear-shift
Postby Stephen Dean on Mon Feb 14, 2022 9:23 am
The two devices that Dave has suggested will both work based on the information provided. I have used the KA sensors strain gauges in a number of installations without issue.
Postby Ralle#67 on Tue Feb 15, 2022 11:39 pm
thank you.
I ordered the Cordona sensor. do I have to use digital or the AV input of the M170 for the signal?
Ralle#67
Postby Stephen Dean on Wed Feb 16, 2022 10:57 am
It should use an AV input.
Postby Ralle#67 on Mon Feb 21, 2022 1:04 am
I got the Cordona sensor and connected it.
but I still have the two messages:
No valid input
and low-fault.
I used the Sensor 0V, Sensor 5V and AV Gear Shift force connectors on my wiring harness.
Thank you
Ralf
Ralle#67
Postby David Ferguson on Mon Feb 21, 2022 6:19 am
I suggest posting your current package, plus any details on your wiring harness (which AV input is used for your gear force sensor)
Postby Ralle#67 on Thu Mar 03, 2022 5:46 am
I use AV 8 for Gear Shift Force.
Ralle#67
Postby David Ferguson on Thu Mar 03, 2022 6:24 am
In your package, on the Transmission->Gear Shift Analysis page. What are the range of values on the channel "Gear Lever Force" when you activate the shifter both up and down with the clutch in (computer connected, engine can be running or not -- try both.
You need to look at those values and either change the "Gear Lever Force Threshold Up" or "Gear Lever Force Threshold Down" you'll see this on your Transmission->Gear Shift page.
Or alternately, you could change the scale of the sensor so that it reaches the current values. The Sensor input is configured on the Setup-Inputs->Chassis A page. You need to make sure the Gear Lever Force Sensor Offset is correct when there is no force on the sensor (just highlight the line and press "Q" with no load), and the direction of the force is positive on an upshift direction (ie, Gear Lever Force is positive). If you need to invert it, you can change the sign of the channel "Gear Lever Force Sensor Scale"
Postby Ralle#67 on Thu Mar 03, 2022 6:49 am
Thank you David!
Ralle#67
