M1 Traction Control adjustment
HI, how would I go making a simple adjustment to Traction control?
My tuner has got it pretty close referring back to data, but since then I have changed the diff ratio from 3.92 to 3.07, and I feel It needs less Traction intervention when dry.
I thought to adjust the traction Aim Compensation Gear Trim as a simple adjustment to start with, it has small negative Trim numbers in the first three gears,-20 -10 -5 would that be beneficial? any suggestions would help.
10 position rotary switch, M130GPR Turbo, DBW
Regards
Newbie
Regards
Newbie
