(M142-GPRD) 12V4 Faults
I'm installing and setting up an M142 with GPRD package, i've built the package from a GP Diesel V1.1.25.
M142 is connected through a PDM30 to a 12v battery Supplying:12.01Volts. with 0.5A being drawn.
Attached a picture showing the mentioned.
In M1 Tune i get a Low Fault in ECU.Internal 12V4.Diagnostic @6.753 Volts. i read in This post that this is an internal channel that is supposed to monitor the 12v4 internal rail. In that post the problem was that it was being referenced from the battery directly.
-what could be causing the issue on my side?
-any thing i am missing during setup ?
-if this is not an actual issue, would changing the low/high values be ok as a work around ? as i don't to create a habbit of ignoring the warning lights.
Thank you.
Thank you.
