Automatic Transmission control
I have a A7540E Toyota Hilux automatic transmission in my car. I am using a stand alone transmission controller to shift gears. It is not very good. I want to replace the Vipec ECU running the engine with a M1 series ECU. Is it possible to also control the transmission. The A750E and A750F are the same as far as control goes I believe. Four solenoids control to gears and a PWM to control oil pump pressure.
Ray.
Ray.
