Cruise Control for M150-GPR package
Postby rayhall on Mon Nov 15, 2021 2:31 pm
I asked over a year ago about getting cruise control added to the GPR package. I was told at the time that it was being considered as a extra function. My car was built and wired for cruise control with brake and clutch pedal switches . also a control stalk on the steering column.
Will this ever be added or should I have used some other ECU.
Ray.
rayhall
Re: Cruise Control for M150-GPR package
Postby Stephen Dean on Mon Nov 15, 2021 5:02 pm
Hi Ray,
Cruise Control was added to GPR in the July 2019 version 01.11.0000 release. This version was released to the public around the end of September 2020.
Postby rayhall on Tue Nov 23, 2021 10:42 am
Thank you Stephen I have not noticed it on the M1 tune so I may still have a old version
Ray.
rayhall
Postby rayhall on Mon Nov 29, 2021 11:18 am
How do I upgrade my package firmware to version 01.11.0000.
I have version 0.1.10.000 and the engine is tuned. It is a Audi V10
I have a M150 GPR
rayhall
Postby Stephen Dean on Mon Nov 29, 2021 1:24 pm
Hi Ray,
What is the serial number of the M1? I can send you an updated licence if your Dealer hasn't done so.
To migrate the data in the M1, Open the new base file first, and then add your current tuned file using the File | Add Compare Package option in the M1 Tune Menu's. Once both files are open, with the New file on the Left and the Tuned File on the right, go to Tools | Migrate Data and click on the Migrate All button at the bottom left of the pop up window. This will automatically migrate all of the data out of the Tuned file into the new file and give a report after of any issues that may have occurred. Note the errors (right click and select Save to Clipboard to add this into a word file) if any and then Close the window. Click on File | Close Compares Package/s to close the compare Package and then send the new Package into the M1. Do the usual checks to ensure that no discrepancies entered the file on the migration.
