GPR Antilag question
Good day, i've just installed a m130 on a 2004 STI, and have a bit of trouble with the antilag setup. First, the overun fuel cut dose not deactivate when the als is active, i have to disable manually. Second, i've opened the throttle plate 15% and set up the als engine speed limit, even though i'm running -500 limit number, and i have no spark cuts, the car puffs black smoke from time to time during idle. And last, is there a way to change the idle solenoid DC based on the Air table in the antilag menu? The idle DC dose not seem to change no matter what i enter in the antilag map. I would like to have two antilag levels, one with air bypassed just through the throttle plate, and one with extra air through the idle vlalve, how can i make this work? Thank's allot!
PS: Is there a way to make the LTC start after the engine has warmed up? Like in the M800 normal heater function?.
