M150 / C127 boost map
Hi, Ive a M150, 5 button rotary dial and C127 dash.
We've successfully set up all of these, but have come across a curly one. We have 3 boost maps working using the dial, but I've been unable to display these correctly on our dash. Am able to read the dial postition by reading the dial counts, this is where the trouble starts.
As we've 3 maps, the dial position counter can read past the upper maximum if the driver rotates too far.
Maps stay at setting 3, though the count read on the dash can increment both positive and negative.
Is the ECU's boost limit index transmitted over CAN?
If so, what's needed to setup the dash properly, as I'm unable to find this in any of the pre-configured templates provided?
Thanks, Stu
Thanks, Stu
