Brushless Fuel pump -- DHB?
Hi
ECU: M130
Fuel Pump: Walbro/ TI Automotive E5LM pump
Q: How to control the pump via PWM
Desc:
I am looking at running a brushless fuel pump Walbro/ TI Automotive E5LM pump via PWM ,
Options:
I am concerned with temperature saturation in the fuel, as far as I know Ti Automotive BKS1000 controller is on/off switch , no variable speed
Question:
Can I bypass all these Fuel controllers and just use a M130 to Motec DHB to E5LM pump? or do I require a controller inbetween , Fuel lab seems to be my only option
Test Data
Radium Engineering test
Tested flow rate at 45 psi: 577 LPH
Current draw at max pressure: 14.4 Amp
http://www.radiumauto.com/Blog/Post/Rad ... p-Test-100
Injector Dynamics BPC1100 system
http://www.radiumauto.com/Blog/Post/Tes ... EJ0IN_PLCI
ECU: M130
Desc:
Options:
- Ti Automotive BKS1000 controller
Injector Dynamics have a very fancy system in the works the last few years (BPC1100 system ), not released
Fuel Lab do a PWM controller (https://www.fuelab.com/72002-externally ... CSggPD83LI)
Motec DHB
Question:
Test Data
