M1 Inverting boost duty cycle
Posted: Mon Mar 08, 2021 2:58 pm
Is there anything that needs to be done to test and create inverted duty cycle on the M1.
If i test the boost at normal mode it works fine but testing inverted it does nothing so was curious to know if there is anything else that needs setting up.
Boost actuator polarity set to inverting
Also is it possible to do the base feedforward table with an airline and ecu on but engine not started, to get this done before we head to the dyno - but old school but works well as a base
