Cut timing when gear up
Postby Victorgarage on Mon Mar 01, 2021 2:04 am
Can we tell ecu when gear up to cut timing ?
And when paddle shift down.. blip throttle is present
Its on 2015 AT FT86
With m150 plug in
Victorgarage
Re: Cut timing when gear up
Postby David Ferguson on Mon Mar 01, 2021 4:28 am
The Toyota 86 package doesn't appear to have any parameters related to tuning the interaction with the Automatic Transmission. I'm sure anything required is taken care of in the firmware when the Toyota 86 Transmission Type is set to Automatic, but we will have to have one of the developers respond to describe the exact interaction.
Postby Victorgarage on Mon Mar 01, 2021 3:47 pm
i defenetely agree
so the only thing that wrong is the data that the TCU received
TPS i did calibrate corectly
that the only one i recalibrate from the package tune
i am going to try calibrate all data today
wish me luck
and david thanks
Victorgarage
